feartheride
feartheride
- St.Catharines,On.Canada
someone use to sell a little block that you would mont in the hull and it would detect the pressence of water,not a float it had 2 contacts.I have one here somewhere
yeah... it really sounds like something worth trying... :biggthumpup:
Here's a new transistorized type of bilge pump switch that runs the pump only when water is present? The switch with the two contacts will shut the pump off at a ¾” height of water. This switch will run eight seconds of delay time allowing for maximum water elimination. It sounds like a good idea especially if you're running TL to save the battery power.someone use to sell a little block that you would mont in the hull and it would detect the pressence of water,not a float it had 2 contacts.I have one here somewhere
if you mount a pump upside down, i.e. for when flipped, where do you put the outlet? Seriously.... will the pump empty a bilge when the outlet is under :Thinkingof_: ?
I think its a great idea. I do see Oxnards point as it is something elso to fool with. This is a great idea for the surf. If you don't ride surf its difficult to see how this works. When you get separated from the ski and it gets tumbeled arround it takes on water. The ski will sometimes end up upright but full of water. The pump/lanyard idea is good because the ski will pump water while you are trying to get to it. In the surf this can take a while. The ski can get carried in prettty far.
Thanks for sharing Nick.
you don't need it and it robs power (i think)
I think that w/ the outlet going into the tray (like we all do) the pump will be enough pressure to overpower being just 3-4 inches under water...
it would be very simple to do a mock up and test it w/ a couple buckets...
It would be really cool to make this work
How do bilges rob power? :dunno:
Meh....I run dual bilges all day with my TL and I still get at least 2-3 tanks out of it.
Then again, I've never tried it without TL.
