Umi death Part IV & XMetal replacement.
djkorn1
kidkornfilms
Cleveland Ohio
No, the cast part was allready crumbled on the inside. I was hoping it would make it a month. Your DVD show up yet? Shipped on Friday.
Fro Diesel
creative control
Kzoo
Yeah, I know a guy who can make it strong again. It might need a few mods to get a pad on it, but so what!
rock the no pad! I think pads are for girls.
rrp>xmetal>umi>stock I amy go xmetal sinec i won't be able to afford the rrp this season. Glad to hear you are getting the xmetal.
djkorn1
kidkornfilms
Cleveland Ohio
Isn't an RRP heavier than an Xmetal? Pole is off the ski.
stanton
High on jetskis.
atascadero,ca
yea i just got it! good job dude, good mix of everything.
how did the couch hit the jump in the snow i was like oh that was dumb it went straight off but somehow turned around me and my girl were like "no way.. no way NO WAY YAAAAY!!"
i give it
:bigok:
djkorn1
kidkornfilms
Cleveland Ohio
Thanks bro...That was pure luck. It was a 1 in a million shot. It actually almost ran me over before it hit the jump...It hit a mogul and turned the other way! If you look close you can see me on the hill with my camera in the second view.
We only pushed it down once...
Does the video look a little better on DVD?
djkorn1
kidkornfilms
Cleveland Ohio
It'll be back together tomorrow....no problem. I am gonna run w/o a spring for now and just bungee my old pole pad on for now. :):):):), we only got about 3-4 weeks of riding left anyway.
djkorn1
kidkornfilms
Cleveland Ohio
nice!
Found more carnage. Broken Girdle Bolt and bent 10mm bolt from ratchet straps and busted off the front nose piece again, plus I just stripped out the stock pole bracket trying to tighten up the pole.
djkorn1
kidkornfilms
Cleveland Ohio
:unitedstates:New XMETAL!!! :unitedstates:
UMI Steering mounted right up with no problems. :biggrin:
djkorn1
kidkornfilms
Cleveland Ohio
:notworthy: 99% done. Mounted up easy! Bushings fit perfectly. NO GRINDING OR DRILLING NEEDED! I do need to run a spring..it is heavy without one and will slam against the hood bad. I stripped out the stock pole bracket trying to tighten it down...
The steering cable is mounted super cool and sano! Cool setup. I should be on the water tomorrow! :cool2:
