Custom/Hybrid maxx pump..148 setback TWINS
OCD Solutions
Rentz, GA
I'd say let him, be interesting to see what shows up. I'd do a Skat at the same time though for comparison.
The Skat isn't perfect either so i would bet it is a draw on all counts; quality, fit, cost and delivery time.
That's not a bad weight for a full stainless pump either.
For seawater (if you forget the weight)
the solas magnum + wsm housing with replaceable plastic wear ring is the way to go .
make last your impeller forever .
my 2 cents .
just received these today
Looks to be of very nice quality! took a bit of time to complete the order, but in the end the final product was worth the wait. Hopefully it'll perform as good as it looks
there are a few rough edges that need to be smoothed out, and a few sharp edges that need to be rounded off.....but it looks like a hi quality piece!
Well aren't you a proud father ! ......... better have enough to feed them ........ I hear they eat a lot.
nj
i got mine about a month and a half ago def a nice piece the welds are quality for sure pretty consistent also, i showed this piece to a very very good welder/machinest and he agreed it was a good piece. although the new thrust pump is a billet work of art
JetManiac
Stoked
orlando
the welds are not as clean as skats, the veins not ground at the front to a point and it sounds as if they are a little heavier??? Just pointing out comparisons, While were at it, how long did it take and what is the to the door cost?
Inquiring minds want to know.
x2
my 2 cents .
If you prefer this setup, then use SBT liner instead of WSM. Better plastic IMO.
comparison by cost , no way, if these are $1350 they kill the cost of a skat!!!!!
The Skat pump comes with impeller, bearings & seals, cone, and a usable shaft.
I think even buying all that stuff, the Maxx pump is still cheaper - just not that much cheaper.
Max pump comes with cone . I have a 144 on the way . Will put Hybrid ceramic bearings in it anyway so bearings dont matter . Got lots of props already . Ordered this one without driveshaft .
#ZERO
Beach Bum
Florida - U.S.A.
Still needs a special driveshaft for the setback mag pumps and they require a wider double row front bearing due to the shorter vane section.
I would image the shipping cost from Asia is quite expensive too.
$1260 to the front porch for pump . Will pick up another fresh driveshaft soon .
One of the things I prefer about the Kaw pumps is you dont have to have the driveshaft with each one . And there is no midshaft to deal with . I just sheared an SBT midshaft into 2 pieces . Dasa power .
Why are you running an SBT component on a DASA/mag driveline?
