steel horse
X-H20
- Middlesboro, KY
I have a rn sj. Ebox is stock wtb med enhancer. Ski has jss stator and wiring. Jss start/stop yamaha switch and wiring. I've checked the switch and it is good.
The problem is 2 weeks ago I was riding then the ski began to shutter and run horrible. Shutdown and it wouldn't crank. Relay wouldn't even click, checked the fuze and it is good. Take ebx apart when I get home un plug everything And check all wires it looked good so put back together hit the start button And it fired up.
Sat went to ride get ready to put in. Hit start button It fired and sounded like it was missing shut it down and changed plugs then hit start again and NOTHING again. My battery + bolt is rusty but the wire is rust free. What can I check? Is the mad going bad ? Thanks
