ger87410
How did I get here?
- Fort Worth
U got 4 wires for the stator. 2 go to the charging coil and 2 to the ignition coil. The green must be for the ignition coil.
It'd probably be a good idea to replace that wire over the winter, as the spline is most likely to eventually fail. That usually happens when you're on the middle of a big lake with no other boaters are on the lake.
