Ya thats great, hows that FX1 pump conversion comming?
I have been holding on to this picture for a while now, sworn to not show anyone...
Its time to share this concept...
how so? ive thought about doing it to my ski alsoWaaaay too purpose built (limited use).
(Thanks for sharing)
I don't care for it. Waaaay too purpose built (limited use).
Yeah, what wax said...first thing I think of is 3D.
Interesting concept. I had similar idea in mind but 2 bad points took me off this road.
*) Not sure how the ski will react with so much foam taken off at the back. Have you check if the ski will still float if engine bay is under water ?
*) how long can the rear panel resist to strong landings/jumps without the side wall ?
As I said I really like the idea, especially if you are coming from a surfing background.
When running in the ocean side by side with a buddy, you can't safely rub rails (hull has battle scars to prove ithow so? ive thought about doing it to my ski also
Micmac and I have been toying with doing it to his ski... Our two concerns were, 1 strength... all that extra vertical glass must make it 2x as strong and 2nd was with shart turns if it would still lay down and carve...
We still might do it.
