Steering System
munki63
Epoxy is my duct tape
Canada
I have a stock Steering System and im looking for a Quick Steering System where can i get one(A Good One!) and how much should i spend?
JetManiac
Stoked
orlando
X-metal steering
to 701 superjet:
did you use red loctite on the bolt thread and let dry overnight?
xmetal recommends this to prevent loosening.
beachedflunkey
wavejunkies
Virginia Beach
How do i do that?
Move that pivot out at the steering plate, then in a little at the turn nozzle, then loosen the small nut at either end of the steering cable and adjust the big piece (I think counter clockwise) until your steering is re-aligned on center, then notch both sides of your nozzle so it does not bind against the exit nozzle of your pump when you turn.
Something like this (taken before I finished notching):
JetManiac
Stoked
orlando
listen to beach junkie, he speaks the truth. when you modify the nozzle, make sure to sand off all rough edges. The plastic is prone to cracking.
mark 44- where do you get the nut in your post?
