Update, i replaced the stator and the problem persists. I installed a stock head and plan to test soon. Thinking the pitting in 1 of the domes could possibly be causing detonation, making it combust out of time? I'm running out of solutions at this point.
I run my single carb 61x/61 at 165main and 142.5 low it has 185 psi and bpipe. You are not yet out of options. You are possibly looking in the wrong spot.
I have domes that are pitted to hell that rip hard. Its not that, imho. Its starving for fuel.
I gotta pull up the mikuni flow chart graph that shows what part of the carb is activated at what angle of throttle. Its kinda like this:
I dont believe there is enough fuel in the entire circuit. What is the popoff of the carb? Are you using a 1.5needle seat or a 2.0 or 2.3? You have to use a 2.0 or bigger and have a popoff of 25psi or lower for a single carb, again that just my option, but if you dont believe me research the csrb database. You are too lean my friend.
Heres how to square up the popoff once you buy a popoff tester (jetmaniac sells them):
I had a worn throttle linkage that caused this in daytona similar symptoms year. If its leaking around the throttle valve it will never run away or diesel, it WILL require fatter jetting, however.
Please keep posting results
