JayB704
Corona Addict
- Lexington, NC (High Rock Lake)
Just a question, when you do the internal fuel fill mod are you just taking the cap and threaded part from the nose and attaching it to your tank? In so many words....
Yes. With a nice fresh rubber OEM gasket.
Their should be some pics in here about where to put it so that you can still use both gas tank straps.
I'm not seeing the pics of the way to do it using the stock fuel pick up assembly (in its stock location). I like this way best because not only do you get to use both tank straps but when you pull the tank the front is capped and nothing spills.
this?![]()
What was used to cap off the oem fill hole on the front???
There is a thread about this specific topic in the FAQ.
Hold that thought, I will know next week if I am going that route.I have a tank done already if you want it:biggthumpup:
