Internal fuel fill mod?
hangtime
Speak up ,don't kiss azz
Home depot has a pipe cap that will block off the OEM filler on the tank if that is what you are asking .1-1/2 inch pipe cap .it's a piece of rubber that fits over the end with a radiator clamp .
W
wydopen
Guest
that will work!!! and thanks hangtime..good seller with fast shipping!!
meatball
User Title Unavailable
Maryland
The seal that blocks water entry into the hull on the OEM setup (and blocks fuel exit on the internal fuel fill mod), do you guys know if that is fuel safe?
