Im currently working on a Yami XLT 800 that either needs a whole new motor, or just a cylinder. The front piston is scorched on the intake side, apparently from the P/O not torquing down the cylinder correctly (Is this plausible?). My question is, is the bottom end still good?
I checked for grinding sounds and heard none, there is no rust anywhere and there is no up and down play on the rods. What else can I check? Also is there any reason the bottom end would be bad from just a scorched piston due to the cylinder not being tight?
And is there any chance there might be metal down there? It's just scratches, so I wasnt really thinking there was metal in there but might as well ask.
While Im at it, what type of top end failures constitute a new bottom end? Ring failures? Scorched pistons? Piston failures? Wrist pin failures?
This motor was rebuilt before the piston failure so Im not worried about age.
