XMETAL dual bolt question
IceRocket1286 said:
i just threw my pole on my ski, ill have to pass. its all idoks!
youre a lazy, not-wanting-to-reinforce, just-get-my-ski-done-already, go-the-easy-route, just-deal-with-what-i-have, stock-is-just-fine rivetmaster!
im embarrassed for you:crazy:
idok?:biggrin:
Tuscaloosa, AL
idok?:biggrin:
Cough Cough Cough :smashfreakB: :pat:
IceRocket1286
Metro Detroit
idok?:biggrin:
Well, my pole has to come off anyway cuz the bushings are retarted. The dual bolt wont work. Waste told me he hardly had any thread showing on his when he installed them with his UMI bracket and ac pole. A umi bracket is as thick as mine.
WAB
salty nuts
coastal GA
Oh sure, it's the bushings that are retarded, not the installer! :bs2: :Banane01:
I'll take them nuts N' bolts if the Idork passes. He does not need them, I just sold him my X-Metal spacer set.
Now that I think about it, he never even paid for it!!! :rippedhand:
I looked at Lowe's for the correct size, but they had nothing that size in stainless. Still need to check ACE hardware.
i gots 2 ski's biznitch....and if you keep it up :nutkick:
then you wont be invited for
:beerchug:
:439:
then you'll be all alone chatting with some dude on the internet
:Banane37:
then you'll be like:
:damnit:
:scared:
Fro Diesel
creative control
Kzoo
:beerchug:
:439:
:Banane37:
:damnit:
:scared:
Idok is one funny mfer. Just had to bring this up from the bottom of the sea.
D-Roc
I forgot!
you can run a single stock bolt and make your handpole tight, on mine i just cut the larger half of the bushings off, and then tapped in some metal washers between the pole and bracket. The smaller part of the bushing stays in to keep out the play from bolt to handpole. it is steel on steel so it takes less torque to make it stiff. this is with an aftermarket bracket like the x-metal. you can do it witht the stock bracket but it will crack eventually.
