It would happen after a sub or a stab....I'd come back up and the engine still ran, but sounded off. I would gas it, the engine would rev up, but absolutely no output from the pump.
I had to turn it off, and restart.
Problem solved.
I swapped back to my stock flywheel today. No difference. So I swapped in an MSD Enhancer - fired right up. So I re-installed the Vilder - NOTHING. So I put my other Vilder on - fired right up. I'm scarred to re-install this TBM flywheel.
Does anyone know if Vilder is still around, and can I send mine in to get repaired?
Aaron
Sorry, not quite right.
Even though the starter spins it in the right direction, if the timing is too far advanced, the engine can and will run backwards.
I've had that happen personally.
The starter only gets it going - if the ignition fires too early (and both plugs fire at the same time!), it will kick the engine into reverse.
