ATS_Aaron
X-
- Shady Shores, TX
Last year I bought a TBM flywheel. I bought the special one that is supposed to be compatible with the Advent ignition.
I didn't install it until I got my Lamey. When we encountered some running problems I checked timing and found out the Advent was WAY too advanced, like it idled at 35 degrees and advanced from there. Sometimes it would actually start BACKWARDS.
I swapped back to the stock flywheel and it was still too advanced. In retrospect I KNOW the Advent worked fine with my lightened stock 62T flywheel earlier in the season because I had tested it on my Team Scream engine. So now I am thinking the TBM flywheel DAMAGED my Advent permanently.
So fast forward to this year. I bought a Vilder ignition because the curve is programmable and I thought if the timing was too advanced (or retarded) that I could advance or retard the sync setting with my laptop and get it perfect. I got my ski started yesterday....
for about 6 seconds.....
Then it died and never produced a spark again. My guess is that the TBM has fried my Vilder ignition too.
Anyone else experienced CDI failures after installing TBM flywheels?
Aaron
Aaron
