Ok, On the installation of the FP, everything went pretty good except for a few minors that I will briefly mention here. Follow the instructions and think about what is going to go in next and you will be fiine. These were all minor, but I feel are worth mentioning. First was the factory heat sensor that is removed from the exh man. They do not tell you anything about it in the instructions, so you are left trying to figure out what to do with it. Zip tie it up to the wiring to get it out of the way. Next they are now including a water overboard fitting, but it is quite a bit too small for the factory hole that Kawi puts in, so you need to add a washer and some 5200 to seal up the hole. The allen screw adjustments are all easy to get at except this one so make sure to adjust it before putting the pipe in. It took me quite some time to get my hands in there to adjust the bottom screw. The clamp that goes to the water box is very hard to reach, but can be done easily if you set it up correctly. I did not show it here but I did not use their supplied crimp on clamps and it did cause me some problems where I would have to loosen a clamp and slide out out of the way. There are some tight spots around the FP.
