It's not going to work, when you turn your steering nozzle it's going to cause the trim to tilt
The cable would half to be mounted on one side. So turning one way it would be reduced and the other way it would trim upwhy should this happen? The cable gets longer, if i turn... That means, trim is reduced @ full turning the nozzle.
