Super Jet Selfmade Trim Question
Europa
I want to built a Trim like in Picture. Is my Nozzle to far back of the Ski? Will i get problems with handling or something?
Can this work?
Or is the Trim nozzle to short?
I lowered my exhaust. Not quite as low as you want to. As long as you have a waterbox I don't think there would be a problem. As for the nozzle I see many a/m hull setups where the nozzle hangs way out.
Europa
Trim and Exhaust Question
So, i just Try it with ne nozzle.
With the Exhaust i dont Want to have a Hard Start or something, when Exhaust is Full of water. Thats the reason for my question. I will tun pfp Box, so i should be fine.
I Hope :)
jeremy chambon
Need more power
rockford MI
i dont know how you plan on building your trim but heres a pick of mine its a wave radder nozzle with a x2 trim ring and steering nozzle. i can get you more pics if you want them good luck
Europa
Its just put together to show what iam trying at the Moment. But when its like this, there is no Problem with the Steering Cable. Its just an idea, and not the final product. I hope somebody can say anything about the + and -
JetManiac
Stoked
orlando
I think you are barking up the wrong tree.
If you want to make your own trim, then just get an oem trim ring and trim steering nozzle at least.
Europa
you are sure?
Europa
Its just stuff laying around. The Big Black holder, will go deeper, or i dont let him there. Iam not sure yet. Iam just trying this stuff together which i have laying around.
But you can lay the cable through the top of the Pump, theirs enough room. Not for this, but for a normal cable, its no problem. A Holder can mountet in the piece where it is now
you are also not going to be getting much thrust deflection also.
Trust us. Pick up a raider trim ring and steering nozzle, Weld you some bosses onto your stock nozzle and go from there. Search "CATS". When you turn the bars, the trim is ging to pull up some, that cable is not limber like a piece of spaghetti noodle or string. It will be stiff in turn it will pull the nozzle upwards
