Super Jet Selfmade Trim Question
Europa
Its not the final nozzle, iam going to get a longer nose. This is just a Test. I dont like the Trims with side Trim cable. And i dont like to bend the Steering cable that much. But when this go wrong. I try another System ;).
the pro-tec trim stytem pulls from the top. its basically just the trim ring and lever arm stop. and if you use a heim joint cable end, it doesnt bend the cable at all. i have built a lot of trim systems and i have to agree with the guys that said it wont work
Tuscaloosa, AL
you can slot the top pivot bolt hole on the steering cable and use the cable just like you got it and create a trim system without the extra nozzle. I had something like this. It does not have the throw of a standard type trim but it was good enough for making good setup waves and back flips of double up boat wakes.
