Pic of DASA powervalve clearanced for B head pipe?
waterfreak
I had a vision!
s florida
So who all has been able to clear PV's with grinding the head pipe only. Paul L just clearanced my head pipe but no way is it clearing the rear PV adjuster cap...I have ground it down as far as I can go without going through....and this is with the thrust innovations spacer too!
Does it HAVE to be cut and welded?
maybe it is because the thrust innovation spacer is not as thick as the Dasa spacer. I just recently used one for my last 1000cc build and I did not have to cut into the head pipe to clear the rear PV but I did have to grind down the cap pretty flush
Ohio
Why on Gods green earth would there be a thick and thin spacer out in the world? Was that a guess or you know that they are different?
I can't grind the adjuster cap screw flush to the PV cap because the adjuster cap sticks up so much more and is hollow.
Did you mean you just ground the red adjuster cap as far as you could? Because even then I am touching it. I ground it flush with the little depressions in the cap and any more than that and you go through it.
easyrhino
needs more cowbell.
The river
I used the Thrust spacer without breaking thru. I used carbon paper to mark where to grind. And I grinded the bolt boss on the pv to clear the manifold so that the PV could be removed without removing the manifold.
@WaterFreak How much thicker is the DASA spacer? I can't see it going thicker because the bottom of the header pipes hits the bottom of the manifold.
GIL
Power In The Hands Of Few
Cullman AL
Matt, so you got a pv motor now? If so-give us some details on the motor. We have all read ALL the questions about a big motor, so which direction did you go?
waterfreak
I had a vision!
s florida
yes I had both and compared the two! the dasa is a bit taller
Ohio
I'm gonna update my original build thread with pics and details as soon as its all dialed in! BRAP!!
Penrith
I have a billet dasa power valve motor with a b pipe my pipe was ground to clear and I got a spacer made it's 10 mm thick my pipe looks sweet no triming of the power valves at all bolts up easy and I used oem 701 cylinder bolts instead of the :):):):) rusty factory pipe ones I run the spacer on all
my b pipes now power valve or not slight increase in bottem end power I feal
Ohio
Hmmm! Good stuff!
Thanks everyone so far!
