ATS_Aaron
X-
- Shady Shores, TX
Mine did. I ground and tested, ground and tested, and finally poked through and had to weld.
So who all has been able to clear PV's with grinding the head pipe only. Paul L just clearanced my head pipe but no way is it clearing the rear PV adjuster cap...I have ground it down as far as I can go without going through....and this is with the thrust innovations spacer too!
Does it HAVE to be cut and welded?
Why on Gods green earth would there be a thick and thin spacer out in the world? Was that a guess or you know that they are different?
I can't grind the adjuster cap screw flush to the PV cap because the adjuster cap sticks up so much more and is hollow.
Did you mean you just ground the red adjuster cap as far as you could? Because even then I am touching it. I ground it flush with the little depressions in the cap and any more than that and you go through it.
Matt, so you got a pv motor now? If so-give us some details on the motor. We have all read ALL the questions about a big motor, so which direction did you go?
I have a billet dasa power valve motor with a b pipe my pipe was ground to clear and I got a spacer made it's 10 mm thick my pipe looks sweet no triming of the power valves at all bolts up easy and I used oem 701 cylinder bolts instead of therusty factory pipe ones I run the spacer on all
my b pipes now power valve or not slight increase in bottem end power I feal
