hermanns
poor
- gainesville, fl
I got a new kart tank a week or so ago and was trying to figure out how to strap it down. I ended up rigging something to make the battery w/ stock box work in the middle, right in front of the flywheel. I know XFT makes a kit, but I paid nothing for this. I just took some 6mm threaded rod and stuck it in some of the holes that were free by moving the battery. The left rear on where the battery box bolted, and the one on the left side where the gas tank strap used to be.
Under the battery box, I cut some rubber stuff to make it sit evenly on the bottom, and I shot 2 sheet metal screws into the holes where that rubber thing the stock gas tank leans up against used to go. I then put the battery in, and put a piece of aluminum channel I found laying around across the top on the threaded rod and bolted it down. I am going to add some anti seize to it all, and double nut it, but it it very strong and isn't going anywhere. Hopefully this will help center the weight, because my ski leaned to the right real bad.
Anyways, here are the pics:
