I thought the stuffer cone was an improvement (I think) but not worth it IMO. I tinkered with it for a little while before ditching it but could never really tell if it was really better or whether I wanted it to be better so my mind made it feel better. Yes, it's $300 for a stuffer cone and you can get a used mag pump with prop for $1k or less if you are patient. Look at this way though... $300 for a stuffer cone and I sold my stock pump with a 9/15 hooker prop for $375 with stock cone and a stubby cone for another $35. So my "poor mans mag" was worth $710 and my real mag with prop was purchased for $900 shipped. Just wanted to put things into perspective...
this is actually one of the best posts in the thread
i was against the tbm stuffer as i tried one with no difference... pixie dust as i called it and the biggest waste of my money..
.. however.. i never ran a large hub prop.. and i know some of the local guys went this route and it makes a difference with the big hub prop
but then when you compare the prices... tbm stuffer/big hub prop vs mag/prop .. you are only $200 apart!
im always amazed that guys will spend all the $$ on a big motor and then not on the pump.... if you cant transfer the power of the motor, then whats the point?
i just added a 9/15 hooker into my 144mm set back mag and the difference was huge! best mod out there..
... now next point .. set back vs non set back .. ive had both... dont think its worth the difference in price, no extra performance seen
the design of a set back seems flawed to me as the bearings are way to close together.. just my opinion
now if someone was looking for a mag, i ran a 148 mag with a limited 701 set up... was the best set up i ever had
for all the money people will spend on candy ... save your $$ and buy a mag!
