waxhead
wannabe backflipper
- gold coast
:bs2:
wrong, combustion happens in the cylinder, that forces the piston down, and the decompressing gases are released into the pipe chamber where they do most of their expansion, (hence the term "expansion chamber")
and you're saying that I need to do an in depth study of this!?!?! you've got to be kidding man, seriously.
A two stroke exhaust system is a pressure wave device and works on sound waves
It has nothing to do with expanding gases
Its about the sound wave causing a negative pressure and drawing fuel air mixture out of the exhaust
this is what we call scavenging
I know this is above your head
but maybe if you wanted to actually have a look at something other the clymer manual you have then you may learn something
the expansion chamber is a pressure wave device not a secondary device to allow for expansion of gas
Try reading a link like the one below
it may actually teach you something more then the clymer bible you hang so dearly to
http://www.maxxtraxxusa.com/Tuned_Pipes_3608.cfm
