Help with Madmats Clogging Problem
Ohio
The dry pipe issue has been solved. It simply cannot be ridden without a strainer. That was the last 2 years. This new issue was 2 heavily clogged 90's that clogged at different times on different skis. Then when I swapped motors/pumps I discovered those and all should be golden now. What a nightmare. Needless to say next time anything clogs I will be able to tell where because now I know how easily I should be able to blow back thru the system. Their is zero resistance on a clean system. If you feel ANY then their is someting going and the 90's need removed and inspected.
As for my Speedwerx dry I love it but it has to go. I'll be in the market for another B soon.
Only when it clogs.:banghead:
However, I am ready to flush everything I own downa giant toilet.:biggthumpup:
get yourself a blowsion style flush kit............flush thru your pissers ONLY
that will give you a true backflush and hopefully wash all that crap outta there....
who knows, mayve if you flush weekly you'll only clog monthly?
both butti and I clogged up our systems simultaneously on sunday....he was able to splash his loose, but not me...we got hit with the COQUINA rock...which is basically crushed shells.....
