- Ocala, FL
Anyone done it? My engine is most likely pretty messed up so I was wondering if I can swap in a gp800 or would I be way to far over my head?
Maybe with a kart tank.
I don't know....seems like alot of work.
Did you do the 140 or 144 conversion yet?
I see you sneaking around in here Boggess.. Don't be getting any ideas.
Like putting a big block in a geo metro. Im a fx1 lover but I cant see the logic behind such big power in such a narrow, porpoising, loose handling ski.
Come on Trent... Wheres the American (Go Big Or Go Home) Spirit?
Now that i bought my "Wifes" fx-1, i have 2 hulls to play with. :wavey:
My builder said if i get the motor and hull to him, and he can start from scratch with it, he will fab it up...
Now i need the motor, which might be in my reach right now.
My thoughts, a stock 800 puts out 120hp, highly modded big bore prob around 100. Stock is going to prob be more reliable. If not, i will have a spare 754 Big bore in the garage..
FLAT WATER BACKY HERE I COME
that the BEST type of hull to have big power in.......The Fxscream is a handful, but theres not too many skis out there that are more fun to ride...
the motor is the easy part.....start thinking about exhaust options first
you can use a WDK wetpipe....but it will have to be cut and rewelded to fit and a big pump is mandatory..
I dont think I'd want a gp motor pushing a kawi 650 pump haha....
a GP motor in an fx would be AWESOME..but its tons and tons of work, lots of money and you have to build it with parts that arent really manufactured...they're out there, but EVERYTHING will be custom.....
By "king of failed fx1 projects" do you mean a botched pump swap and a wasted hull cooler?The King of failed FX1 projects says, "Thats Dumb."
Depends on if you can get your hands on an upright mounting kit. Waterdawg makes one and there is another guy on the boards making one. They will make things much easier. You can also relocate the front motor mounts but that is much more work.Would the motor bolt up to the fx1 motor mounts or would i need some kind of custom bed plate? Other then exhaust it doesnt seem like it would be that hard.
And when i say my motor is "pretty messed up" i mean im probably looking at a new crank, new pistons, new head, and maybe a new bottom case if i cant get the starter bolt and easy out that both broke off out.
