WFO Speedracer
- Alabama
Ok It turns out that I have a Clymer manual for 97 -2001 Seadoos , the Programmer code list is in there as well as the list for Buds , yeah I know I was as surprised as you are.
I will tell you this I didn't find it anywhere on the Internet . I will probably post it to a couple of different sites like PWCT and Greenhulk so the next guy can find it .
I cleared the code , cranked the ski and checked for any new codes, the only code that came up was the normal one for the crankshaft sensor.
So I am guessing either the pressure regulator and or the injectors are clogged up ,the ski cranks up normally and runs perfect on the trailer , pressure regulator is on the way here and I have the injector cleaner I built last year , what I am going to do since it has to have four injectors in the cleaner to operate is pull the injectors from this machine and the one I just acquired , mark them so they don't get mixed up and clean both sets.
Then I will install a set with the new regulator and go run the ski again.
