- Harvey's Lake PA
So I’ve looked all over and can’t find a post about a engine runaway. So I don’t really know what it is. Is there a post that I can’t find? And what do I do to make sure it doesn’t happen to my engine (650sx) ?
https://en.wikipedia.org/wiki/Dieseling
If it happens cut airflow to the motor to stop it (put a hand over your carb(s)
That doesn't work all the time. I tried hands on the trumpets with my SXR...didn't work. I then opened the Choke and that killed the engine.
It happened twice with my SXR, each time I was past Reserve and started it once back on the trailer to clear the waterbox. The first time I didn't know you could just pull the throttle open. Air in your fuel lines can cause the same issue as an air leak.
So, the easiest- especially if the hood is still on- is to cut ignition and open throttle all the way. Engine will stop.
Or open the throttle. Seems counter intuitive, but it has never failed to stop the motor run away.https://en.wikipedia.org/wiki/Dieseling
I would NOT put my hand over the carb. Dont even want to think of what could happen it it decided to strip the skin from your palm.
Sent from my SM-G930P using Tapatalk
@augustaf you coming to Daytona!?So, the easiest- especially if the hood is still on- is to cut ignition and open throttle all the way. Engine will stop.
