Super Jet De winterized ski wont run right! Need help!
when i take the needles out were is the screw spot to take the jets out
^^Read the manual.
The jets have nothing to do with the needles.
You need to take the diaphragm cover off, then the diaphragm, then the jet block. Pilot & Main jet are under there.
READ THE MANUAL.
Edit: LOL. Not being a dick, but that manual really does cover all of your questions. Also how to tune the hi & lo adjusters.
Fro Diesel
creative control
Kzoo
You definitely just need to get a bpipe and it will just be great. Yeah...great.
sent from Fro Diesel using tapatalk.
what do u check with the needle and seat i think it looked good? one of the seals looks bad i think and the diaphragm will not fit back in the slot anymore and its all warped.
any positive help? How can i tell if i need to rebuild the carb?
If you can't Remember when it was done last, it needs to be done. It's not running right, so it would be a good idea to rebuild carbs.
Buy genuine mikuni rebuild kits (no aftermarket crap!) and new needle & seat.
What to look for in needle & seat: if you can see a groove in the needle tip, however small, replace it. Check the o-rings on the seat
ok thanks only had the ski a year so i have never done it the needle and seat does not look like it has a grove in it at all it looks smoth and good
