96' build, Foot holds/turf time !
nikad58
1974 YZ 701
Just wondering if anyone else has glassed on their nose peice.. I cut the ears off the nose piecec so the pole bolt/bracket can be removed and will add another screw (2 each side) to hold the ears on.. I filled the stupid bumps on each side of the tray tops (gunwall?) the gas fill hole and been doing some safty reinforcing for Matt E !! haha
After foot holds and turf it's paint time !
oxnard111
Creative RE Purchasing
looks nice... i'd like to modify that area so that the pole bolt can be removed without taking the bracket off when using a lowered pole bracket. don't know if that is your objective or not.
oxnard111
i'm not even talking about the nose piece... with out the nose on, you still can't get the bolt out with out loosening or completely removing the pole bracket.
But cutting one side of the bolt would probably work. Every bracket is not the same so it may work with some and not others though. I think the WDK bracket is even too low to just to shave one side of the bolt's head. I know for sure it is lower than the blowsion bracket.
Hurr? I admit that it's been over 2-1/2 years since I've had a single pole bolt, I don't recall having trouble removing/installing it.
Probably just my ********ty memory.
norcal ex
X-H2
San Jose, CA
You can shave the bolt... thats what I did with mine and it works...
