- Idaho
It seems that there are a ton of questions, ideas, ways to mount cameras and such while riding. Most are posted sporadically in different threads. I figured we would start one just for this purpose where people can share different mounts, tethers, flotation, etc.
I use a GoPro wide. I have the original mounts in which I use a key chain floaty and tether. I have had it break from my old fish line tether so I am re-designing a new one. Luckily the key chain floaty works and it is easy to see in the water. There is one zip tie under the latch attached to the floaty and one around the camera to keep the floaty from flapping around. This second zip tie also works as a backup to keep the case shut if the latch ever fails. Recently GoPro also came out with the wrist case for the wide angle lens. I have just started using this and have found the O-Side crew boys mounting to the helmet the best. I still need to make a flat mount to help the camera sit flush to the face shield.
