- ARGENTINA
Boys HELP:1zhelp: HELP:1zhelp: HELP my motor is DASA billet power valve stroke 16mm and piston 90 mm my configuration.
+16mm Crank
90mm Pistons
180psi Head pump gas
RIVA 48mm Carbs
VFORCE 2
Prok Flame Arrestors
MSD Total Loss System
PFP power factor Dry Pipe System
Skat Trak Mag Pump 140, 12 vains.
Skat Trak Impeller .12/18 (144) ?
My problem is to comfigurar everything?
timing curves msd? to impeller? carbs jeting low and high and seting. My hull is XFT CARBON for freestyle. my intension is back flyp in flat water acceptance all the suggestions-:barrel:
ALREADY CRASH 5 PISTONS OF THE SIDE OF EXHAUST PORT.
… what is the safe configuration ???
+16mm Crank
90mm Pistons
RIVA 48mm Carbs
VFORCE 2
