Corroded bilge outlet
Does anyone have a good way to get a corroded bilge outlet out? Ive tried everything i can think of to get it out. All ideas are welcome
im in the same boat as you. ive tried pb blaster+heat and a vice on the nut and a vice on the outlet its self and its still not coming off.
The only thing i can think of is to dremel it off, but depending on where you put it, it might be hard to do. I cant really get to mine im really thinking of cutting around the fiberglass and just filling the hole.
Will that corrosion come off with that CLR calcium lime and rust remover? I just thought about that. Might give it a shot. I would just cut the nut off with a dremmel and then glue the outlet back in with some silicone if you want to reuse it. A tiny bit of silicone will hold it forever. Unless you push the hose back on too hard then it comes loose
Is it stainless? It looks like it is, either that or polished aluminum. I just can't see stainless doing that unless it was made out of something like 440 stainless. Aluminum yes, it gets that white powder all over it and in time gets eaten away by it.
If its 440 stainless, a magnet will stick to it. If the magnet doesn't stick then its most likely aluminum. The good stainless (304, 306, 316) won't corrode or rust but also won't let a magnet stick to it. I have stainless gear clamps holding the fill tubes in place on my truck's gas tank and the only part that rotted away was the cheap mild steel gear portion lol. If that thing is aluminum you should have no problems marking it up with a drill bit or something. If that's the case it will cut off real easy as long as you can get a dremel or something in there to cut it.
Yes sir, stainless sucks when you can't get at it to remove it. To see if it's aluminum, you could also use a dremel with a sanding drum on it and see how hard it is to sand into it, aluminum will sand down pretty quick with an aggressive grit count....I mean like 5-10 seconds should show a substantial loss of material. Stainless would take probably 20-30 seconds to make it look oogly. I'm out for the night, hope its aluminum, have fun with it :bigok:
Shifty
- SuperJet Thursday -
I agree, CLR or LimeAway and let it soak and penetrate the threads. Another idea if the threaded portion is thin enough, you could maybe crush it enough to wiggle the nut off?
