**New Short VIDEO** GO PRO bow eye mount, sweet barrel roll shot joe kenney style.
check it out. the new mount for go pro wide!
<object width="400" height="300"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=3993666&amp;server=vimeo.com&amp;show_title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=3993666&amp;server=vimeo.com&amp;show_title=1&amp;show_byline=1&amp;show_portrait=0&amp;color=&amp;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="300"></embed></object><br /><a href="http://vimeo.com/3993666">Oside Crew- GO PRO FRONT MOUNT</a> from <a href="http://vimeo.com/user1015052">matt smith</a> on <a href="http://vimeo.com">Vimeo</a>.
Crab
thanks darin...noswad!
Seattle
thanks guys, i'll get some picks how to mount. should fit anyski that has a front bow eye. basically a galvanized pipe 3/8 with a cap on one end and the go pro angle mount on the top.
I did one out of a 1.25" pvc tee that bolts thru the nose eye.
227
Its all about the surf!
Oceanside, CA
ah you must have that blowsion nose piece then huh?
You don't need Blowsions nose piece, just cut your stock one. Matt's is set up just like mine.
