Hollow titanium bolts, Allum crank case plate, Allum RRP style pole, & Allum Mag pump
Jawbreaker
Rick James Edition
Music City, TN
Thought I would post some of these pics... I know BUN parts here in the states are expensive, but they have some kewl parts. I like the plate for the bottom of stroker crank cases and the hollow Titanium bolts!
Opinions welcome... Lets hear some feedback.
Jawbreaker
Rick James Edition
Music City, TN
More pics... Aluminum RRP style pole, billet big bore cylinders, and aluminum Mag pump!
Check out the 2nd pic of the top of the hand pole where the turn plate attaches. It looks as if its adjustable.... as if you can change the angle that it sits...
Jawbreaker
Rick James Edition
Music City, TN
Few more pics...
oxnard111
Creative RE Purchasing
I'm not understanding how/what they did to the cases to prep it for the installation of that plate?
Is it just a girdle so that after clearencing the cases for a stroker crank the now thin cases won't crack?
SuperJETT
none
mcmaster.com has titanium hose clamps now. They'll go well with those hollow titanium bolts that will allow saltwater to get directly to the bottom to start corroding instead of having to slowly creep it's way in.
THRUST
ThrustInnovations.com
bring your pcket book . the prices are up there even without the shipping . but good quality parts . the cases are reinforced with epoxy then decked smooth and capped with the aluminum plate for reiforcment and so you wont damage the epoxy .
When clearancing for 10-12 mm cranks it will go thru the bottom of the case.The bottom of the case is filled then machined flat for the plate then the plate is bolted and sealed to the case.It is basicly a case extension 4stroker crank's.
I hear ya,id love to have that pole as well,infinite adjust ability would be so cool,wonder how they get away with such a close copy to the RRP........just better
