WDK F1 pro teaser pix **weight added!
well I got my boat back from slutty...build should be on SOON!
bottom deck is a 50/50 glass-carbon with a layer of chop on the top...if you look at it straight on, you can see the carbon thru the chop..
top deck is just glass im pretty sure....
the stringers are plexus'd in and then glass reinforced....pumper dumper 1 way valve
Dry Weights:
117lbs foamed hull, hood, turf
131lbs hull, hood, pole, bracket, bars, new WDK steering
Umm...what the hell kind of paint job is that? Did wavedemon tell you to do that?!?
the boat came primered from WDK......
slutty sanded some of it off when he did the turf......the hood was used, but the hull new
going to leave the bottom glossy black for now and try and match the topdeck as best I can......
black on black on black with camo turf :headbang:
butti
lone wolf
F-XTC
not yet..
I cut 2" off the REV rideplate and added a large Dcut...I want to see how it handles
might also shorten a steering nozzle and bring it to the beach to see if that makes any difference..
just ride the ********ing thing!no matter what you do it wont ride like your old ski.your sj weighed 100lbs more for starters!
just to give him business or you can't do it? if it is the latter, that surprises me...
I have and can do it...but admittedly not nearly as clean as Nick's result...I was a bit nervous with the REV install into the fx1..plus I wanted the patented slutty mod tray..
plus its always nice when you can help out a friend! :Banane01:
he turned them around for me in about 2 weeks..WAY faster than I would have gotten it done in..
oxnard111
Creative RE Purchasing
haha... good call... i was just wondering.
I would much rather pay a little to have that kind of stuff done...fiberglass work is not fun and sanding makes a friggin mess. If you live near Nick, let him do it! Plus then you know it will be done correctly...like having Blowsion do your fiberglass work only on the other end of the country. :)
he also fixed the rear lip where it was razor sharp, fixed all the imperfections from where it didnt release from the mold, and foamed it.....
