Fin
Well I made my deadline, everything worked fit great the gas tank was a pain since the hull doesn’t flex much anymore. I lubed it up and just forced it, figured if it broke from that better redo the whole thing. I took off the fcv and also did somthing new on the gas tank breather, got rid of the water separator also. All new hoses for cooling and also I got the gas tank in strait and flat notice on the old pic. The connection to the water box and stinger is spot and I am going to be ok clearance wise too. Pesky pipe. Anyways I just wanted to let you know that I am a lil rushed on the computer my mind is always thinking bout the next and I just type sorry again if it is hard to read. The pics are important so I took a few they helped me do this project. Again I was more worried about finishing this project in a few days then typing and spelling errors. My nose I good to go I am prob 80% healed and breathing is great I recommend the surgery you can test your self by plugging your nose with your fingers and blow out nose not letting air out and then let go and breath through nose only if you can breath clear and more than normal and 3 seconds later it gets clogged again maybe 1 side only then you may have to consult and ent. And go from there they will use and endoscope and check you out. Wish me luck tomorrow Oh ya my primer kit isn’t working could it be the fuel not filling all lines its tapped into the reserve. And is my new tank breather ok. Thanks again guys for tips all couldn’t have done it without you.
