oxnard111
Creative RE Purchasing
- so Cali, Ventura/Oxnard area
1997 SuperJet.
Check newer posts for what she's lookin like now.
(updated 6/9/09)
Engine/Driveline/Electronics - :brap:
62T Cased 61x Jetworks Ported cylinder, 81.5mm bore, weisco pistons, Hot Rods Ture welded
B-Pipe, Mod Chamber
Cold Fusion Generation 3 cylinder head
Riva Single Carb conversion manifold
46mm Black Jack Carb
Wamiltons OEM Yamaha FA adapters
Cold Fusion Billet O-ringed flywheel cover
Cold Fusion Kawi style conversion couplers
Brand New V Force II reeds
MSD Enhancer Ignition
Impros Hooker 9/15
Wet Wolf FreeStyle pump cone
Pump Taped for dual cooling
Lightened 61x Flywheel setup
Monkey Grip engine mounts
JetWorks flow control valve
Full ebox bullet proofing from JSS
Hull/Handling
WaterDawg Diablo lowered hood and nose piece
X-metal single breather tube handlepole bracket, setup with a stock pivot shaft and 750sx pole spring
Wamilton Rickter Footholds
Stock D-Cut ride plate
Worx 205 intake grate
UMI steering system
JSS Tuff Stuff thrust washer kit
UMI sliver straight throttle
ODI Rouge 90mm with flange grips
1" Dump Bilge tube with duckbill
X-metal -2 pole
X-metal -2.5 steering turn plate and bars
total negative length over stock = 5.5"
Chinpad from UCSspriit
Steering pivot on steering nozzle moved inward to gain extra throw
Blowsion Tubbie I (surf/rec) side sponsons.
Full interior re enforcement. 1 layer of knytex on sides, 2-3 in the nose. Sides covered in 1 layer of 5.5oz carbon
25mm underpadding with waffle Grey/White/Black Camo turf
Wamilton's bungee style hood straps
Accessories/Necessities
1 Attwood 500GPH bilge pumps
Rotary dash bilge switch
Black bilge outlets
Black bow and tail bushings
Black ODI locking rings
ODI Black Thug Plugs
Front Tow loop
Rear rope through rear eye hole for towing
Tow rope with dual large carabiners
Primer kit (plunger style)
JetWorks sealed battery (the best one :dunno
Limiting Rope
Stock hood latch with wamiltons hood straps
Kenny Engine Keepers
WDK Hood hooks
X-H20.com stickers
Brand new parts installed during the winter 2007/2008 rebuild
New OEM steering cable
New Monkey Grip engine mounts
New B Pipe Coupler (head pipe to chamber)
New Factory pipe exhaust coupler (chamber to waterbox)
New fuel line
New bilge wiring
New battery terminal cables
New cooling lines throughout
Brand new fully stainless hose clamps throughout the ski
New ODI grips
Before New Hood Setup:
With New Hood and Handlepole Setup, but before tubbies:
This area for pictures of tubbies and re enforcment:
New Turf Job July 2008:
(updated 6/9/09)
B-Pipe, Mod Chamber
Impros Hooker 9/15
- external battery stud connectors
- all new bullet connectors inside ebox
- Stator rewound and JSS quick disconnect stator wires
- start stop switch rebuild with bullet connectors
- Brand new JSS battery terminal wires
Hull/Handling
UMI steering system
X-metal -2 pole
Black bilge outlets
Front Tow loop
Limiting Rope
WDK Hood hooks
X-H20.com stickers
New fuel line
New bilge wiring
New ODI grips
