Chris' Surf Battle Boat... Never done!
oxnard111
Creative RE Purchasing
1997 SuperJet.
Check newer posts for what she's lookin like now.
(updated 6/9/09)
Engine/Driveline/Electronics - :brap:
62T Cased 61x Jetworks Ported cylinder, 81.5mm bore, weisco pistons, Hot Rods Ture welded
B-Pipe, Mod Chamber
Cold Fusion Generation 3 cylinder head
Riva Single Carb conversion manifold
46mm Black Jack Carb
Wamiltons OEM Yamaha FA adapters
Cold Fusion Billet O-ringed flywheel cover
Cold Fusion Kawi style conversion couplers
Brand New V Force II reeds
MSD Enhancer Ignition
Impros Hooker 9/15
Wet Wolf FreeStyle pump cone
Pump Taped for dual cooling
Lightened 61x Flywheel setup
Monkey Grip engine mounts
JetWorks flow control valve
Full ebox bullet proofing from JSS
  • external battery stud connectors
  • all new bullet connectors inside ebox
  • Stator rewound and JSS quick disconnect stator wires
  • start stop switch rebuild with bullet connectors
  • Brand new JSS battery terminal wires
Hull/Handling
WaterDawg Diablo lowered hood and nose piece
X-metal single breather tube handlepole bracket, setup with a stock pivot shaft and 750sx pole spring
Wamilton Rickter Footholds
Stock D-Cut ride plate
Worx 205 intake grate
UMI steering system
JSS Tuff Stuff thrust washer kit
UMI sliver straight throttle
ODI Rouge 90mm with flange grips
1" Dump Bilge tube with duckbill
X-metal -2 pole
X-metal -2.5 steering turn plate and bars
total negative length over stock = 5.5"
Chinpad from UCSspriit
Steering pivot on steering nozzle moved inward to gain extra throw
Blowsion Tubbie I (surf/rec) side sponsons.
Full interior re enforcement. 1 layer of knytex on sides, 2-3 in the nose. Sides covered in 1 layer of 5.5oz carbon
25mm underpadding with waffle Grey/White/Black Camo turf
Wamilton's bungee style hood straps
Accessories/Necessities
1 Attwood 500GPH bilge pumps
Rotary dash bilge switch
Black bilge outlets
Black bow and tail bushings
Black ODI locking rings
ODI Black Thug Plugs
Front Tow loop
Rear rope through rear eye hole for towing
Tow rope with dual large carabiners
Primer kit (plunger style)
JetWorks sealed battery (the best one :dunno:)
Limiting Rope
Stock hood latch with wamiltons hood straps
Kenny Engine Keepers
WDK Hood hooks
X-H20.com stickers
Brand new parts installed during the winter 2007/2008 rebuild
New OEM steering cable
New Monkey Grip engine mounts
New B Pipe Coupler (head pipe to chamber)
New Factory pipe exhaust coupler (chamber to waterbox)
New fuel line
New bilge wiring
New battery terminal cables
New cooling lines throughout
Brand new fully stainless hose clamps throughout the ski
New ODI grips
Before New Hood Setup:
With New Hood and Handlepole Setup, but before tubbies:
This area for pictures of tubbies and re enforcment:
New Turf Job July 2008:
oxnard111
Okay... Its been about 2 months since installing the hood. I really like it so far. The hand holds are like fish bowls but I can live with it. The hood is holding up just fine, but I'm not that hard on it.
One thing I can say that I see as a down fall of only having the breather holes on the hood in the back is that when I'm in the surf and I get stuck on my tail, if the both holes go under water, the engine just chokes out. Some times it take me a second to get back on a plain, especially with the D-cut stock ride plate. I was almost thinking of opening up one or two little tiny holes in the front of the hood to compensate, but if I an x-metal bracket I wouldn't have to worry about that, now would I ??
oxnard111
I'm installing a X-metal pole on my ski and just as with everything else PWC related, I have had some hickups.
First I ordered the pole way too short, so it took about 2 weeks to get it changed out for a tad bit longer one.
Second, I realized after ordering the pole, that my blowsion chin pad wouldn't fit on the pole. No problem, I ordered chin pad from uccspirit (most likely spelled wrong). Great chin pad. So strong, and looks really good.
Third, I am wanted to run an x-metal backing plate that I had lying around, with the WDK bracket. I had to open the center between the two holes up. That formed a nice Mickey Mouse look to the plate.
Fourth, the bolts that I recieved with the WDK hood hooks were too short... So I went out and purhcased new socket head bolts and nylon lock nuts to install the hooks and backing plate to the hull. The local hardware store didn't have the same style bolt as the bolts that came with the WDK hooks, so I purchased something a tad bit larger and opened up the holes on the hood hooks a lil'.
Now, since I still like to have some spring to my pole even though I crank down the bolt, the round nose blowsion spring I have would not work with the x-metal pole. There is no lower lip on the pole for the spring to catch on. So I took the stock spring from my square and modded it to fit with this WDK bracket/x-metal pole combo.
That is where I left off for the the night. Its all down hill from here. Tomorrow I get my x-metal turn plate and bars in the mail, so that can be slapped on after I finishing mounting the pole.
oxnard111
I got spring fabing all done this evening. Took some bending and grinding but it fits really well. When the pole bolt is not tightend, it still holds the pole up pretty high. I was impressed for a stock square spring.
Edit: I just remembered, this is an aftermarket stronger square spring. No wonder it held it so well. haha
The rest was pretty straight forward. Just put pole on the bracket, then put the bracket back on the ski.
I also installed the steering system. I used the JSS thrust washers. All the o-rings and the bearing that were in there since I purchased ski were perfectly fine. I cleaned the threads of the steering post with brake cleaner, and used a new nylon lock nut saturated with red lock tight.
ODI grips will not go onto x-metal bars. The grip area is larger than the rest of the bars. I took a grinder to the bars to get the grips on.
Here are pics of the pole on. Chin pad has not been bolted on yet, and I still have some odds and ends to tie up. The pole is a tiny bit crooked as you can see from the second picture below by a couple degrees. Over all there are a couple of flaws in the pole, but this is the worst.
oxnard111
Got everything installed.
The steering cable stumped me for a little bit, but I figured it out. The steering plate was not hitting the steering stop, but once I adjusted the cable ends, everything was fine.
When I was putting everything back together I ripped a wire out of one of the harnesses for the start and stop switch, so that sucked...
Over all, I had to do a lot of custom stuff to get this pole to fit. It looks really really good. The chin pad I got looks great on the pole. I'll take some more in better light, but this is what I got right now.
'Crockett
Freelance Smartass
Hey Chris, Ski looks real good . . . . . . it's come a long way since it was the wifey's playtoy. . . .
Now it's a "man-ski" for sure . . . Lol ! . . . . I'm glad you're having fun building it.
Did you get those brackets you wanted taken care of yet ?
oxnard111
Are you talking about the handlepole bracket backing plates, or the fire extinguisher bracket?
I have the design for the handlepole bracket backing plate traced on cardboard. No need for the fire extinguisher bracket any longer... I went a different route... I just put a strap in the front of the tray to hold a square nose extinguisher holder box.
'Crockett
Freelance Smartass
I never did anything with the F/E bracket because you never came up with a sample of what you wanted. :dunno: I'm glad you got it worked out anyway.
I can do the backing plates if you want. . . . . just let me know what you want and sends some dimensions . . . . . . . stainless I assume ?
:biggrin:
oxnard111
:biggrin:
I'll send you some dimensions soon, but I don't think stainless is necessary. The x-metal one is only aluminum, so I think that would sufficient.
you gonna go to pismo this october... if so I can't wait to see the SXR (if its done by then.)
'Crockett
Freelance Smartass
I'd like to do Pismo in October, just depends on how much time and money I spend in 'Havasu during World Finals. Lol ! . . . . . .
I doubt I'd be bringing the SXR anyway, I'd rather ride the Superjet in the surf. I'm sure the SXR will make it to the ocean eventually, once the new wears of of it and I'm used to riding it.
The motor is going in the SXR tonight if all goes well . . . . . . hope to have it on the water by next week ! . . . Whoo hooo !
I've had my Superjet to ride with a new/fresh built motor this year so the SXR build has just been for fun. I'll be glad to have it done but it hasn't been my #1 priority.
W
wydopen
surfriding at pismo>going to havasu :cheer:
