I second that!I would rock the rashed up sides as a reminder of what could happen and for the story! Fix what's broken, but leave the battle scars!
  Pulled the motor completely apart. Split the cases. Pistons are fine. Cylinders need a resurface but look great. Crank is done and will need to be rebuilt. Head is untouched. Case is perfect. Stator was already on the way out and had already bought a new one but never installed. Flywheel is fine. Ebox had some water but I think will be okay. Need to test it.
 Pulled the motor completely apart. Split the cases. Pistons are fine. Cylinders need a resurface but look great. Crank is done and will need to be rebuilt. Head is untouched. Case is perfect. Stator was already on the way out and had already bought a new one but never installed. Flywheel is fine. Ebox had some water but I think will be okay. Need to test it.I absolutely love when horror stories end like this. Can't believe that ski washed up with the hood still on!
My last kiss goodbye......View attachment 321818
....with the sharks on a full moon...
Seriously glad you are ok, man. What type of helmet was that? This scenario makes me want to switch back to the cascade brand white-water style helmet. But lets start a go fund me fo you and your group to all get tow ropes!
Great to see a good ending to a scary story!
Just out of curiosity what kind of flotation do the tiger crafts have?
