I thought about doing that, but I was advised by Art out at Jetworks not to do that and Factory Pipe said the same thing.
To what are each of your screws set?
I have to respectfully disagree with Art and FP, but they bury me in credentials.
I doubt your line was the problem, I have had hose clamps that would not stay tightened, just replaced and it stopped.
I can understand why the lines on the pipe would be melted after the hose from the cylinder to the headpipe popped off, but why would the actual line from the cylinder to the headpipe be very soft and melted.
The lines went from very hard and rigid to very soft and squishy.
Yeah I picked some black goodyear hose from Autozone this evening that I'm going to try out.
It doesn't look that great, but I think it should hold up pretty well.
Run your line out of your head to the BOTTOM of your pipe then out the top to the stinger. That way, the pipe remains filled with water and subsequently remains cooled.
Well after taking more hoses off and inspecting them I found a major clog.
It was in the T between the headpipe and stinger. The only part of the T that was clogged was the part that went to the bypass. The part of the T that went to the stinger was fine so the stinger was getting water.
I guess this could explain why my headpipe heated up and caused the hose that was connected to it from the cylinder head to melt and pop off.
See picture below:
bzzzzzzzzzzzzz. eh, nope!!!!!!!!!!!
if that was the case, all the water would have just passed into the stinger, may have loaded the waterbox more but not gonna contribute to the overheating...........
thought it was a 4mm restrictor, but either way, dont think that would be the cause, but who knows at this point unless you want to fix the hoses, run it again and see what happens. also, if you cooling line from your head to pipe comes off, the hot gasses from the pipe can work back into the hoses at the stinger fitting, heating them up also since no water is being injected at that point!
I was talking to royal flush not too long ago about cooling lines...he was using some air compressor hose with a white lining on the inside of it...
he said it got VERY soft and melted....
