Haha matt trust me it was a fn mess used a whole thing of cat litter. Then I walk away for one minute and my two year old had her hands all in it fml hahah
N&S are fine. Anything else to check before I close carbs up? Filters were fine. It sat out in the sun for a day. Would the pressure in the tank cause that?
I'd guess the waterbox sludge too. Or maybe oil that condenses in the crankcase from sitting. I had a 550 vomit that all over my garage after not running for a long period of time.
Mine does the same thing and if it sits on the beach it floods. N&S are fine on mine too. I had to put a fuel shut off on it and everytime I either pull it with my trailer or it sits on the beach, I have to shut it off or it floods.
Haha! What does masterblaster call that stuff...? Probably your tank over pressuring, especially since you said it was sitting in the sun. Put a pin hole in that check valve so the tank can breath, or just keep it out of the sun...
Double check your long exhaust hose. I had a problem a couple years back where it would block the holes on the diaphragm side of my carbs and hold the needles open, filling the motor with fuel.
