Nice work! To give you some ideas. Here is my '08 called "Mega Deck" It has a dropped pipe, 2" of foam pad on the tray and if you look closely at the primer shots the sides are half the normal width. They are covered with one layer on 1" foam so that it looks stock but is plush on your shin and ankle area. Before this build became declassified it was referred to as operation "pillow top". This ski gives phenomenal "leverage" to rail the ski. It also has a pre '08 steering cable. To utilize all the throw I had to clearance the nozzle and cut about 8mm off the end of the hemi joint as it is to long stock and will "stop out" before you get the full throw. Also heat melted another insert into the steering nozzle closer in on the arm. Anyone who says an '08 won't slash should try these mods.
