Winter Projects
Frosty
New York Crew
Western New York
pulling the '01 SJ apart:
- do a complete reinforcing job
- change the ported 701 to a ported 760
- install new 44s, intake mani and reed cages
- rebuild pump and housing
pulling the '95 SJ apart:
- repaint bottom
ummm.. yeah, i think that's it... i hope that's it.
eschberg
Boycotting Winter.
San Marcos, TX
Going to remove turf and repaint ski. Possible refoam also :banghead:
Still contemplating on switching from 62T to a 61X... but not too sure yet.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
im going backpacking!
:biggrin:
might get around to finishing a couple of engine builds.
Wife wants to tear her white boat down, reinforce, round pole, and paint/turf it.
IM not sure winter will last long enough for that.
Footwells,turf,little hull repair (cosmetic stuff) paint all to the FX1 $$ permitting gotta get it ready for next year probably gonna sell it.
demolition_x
Not After Fame & Fortune
reinforce
hoodmod
footholds
foam
turf
oneway valve
handpole
dual cooling
ada head
62t topend with porting. or atleast a rebuild with a port job
front exhaust
round nose pole conversion or aluminum pole
hopefully some paint.
prob half that list won't get done. but who knows.
Mark44
Katie's Boss
100% one place
Winter projects my ski new turf in try
Katie’s ski cats trim system and scupper vale and I am sure she will think of more like 5 mm stroker.
Mark44
Brap!
Scorn800
Ride for life
North NJ
Just picked up a 94 blaster. that needs paint and to be put back together.
I plan to redo my 03 limited sxr and buy another sxr to make into a surf boat.
So all that plus riding my sled should keep me real busy.
meatball
User Title Unavailable
Maryland
91 sqaure
*slutty hood mod
*refoam and fix air bubble beneath the tray that you can bounce on
*install footholds
*try and get a cheap 701 to replace the stock 650 with (anyone?)
*rattle-can paint
*fix oil-canning of tray wall
*get rid of gay purple graphics and put on some nice ones
*new bilge pump
*three new motors mounts
*new prop $ permitting
*glass a new nose on and internal fuel fill
*new grate $ permitting
*mabye D-cut
*fill in random holes previous owner drilled WTF? Looks like it had dual cooling
*Fix stress cracks
*reinforce
michael950
for me to POOP on!
Houston, TX
Ideally:
Repaint blaster and reinforce the transom.
Reinforce the superjet and add footholds
Definate work on the SuperJet:
Fix carbs (tamper cap and shroud removed)
Remove choke and add primer
ADA Head Install
B-pipe install
Advent CDI install
Returf (remove chitty stock mats)
F
Freestyleriverrat
In the middle of lightly porting 66e cases and roughing up the surface for better fuel atomization. Once that is done I may sell the motor :bigeyes: I think I may do a light weight hull first and selling it will help finance the build.
My winter projects include:
*Finishing metal work on my b-pipe to make it look clean
*Sending b-pipe to be Jet-hot coated
*Impros 12/15 cut back impeller
*Touch up some area of turf on my boat
*Flying out ot Waterdawg Kustomz in OR to mock up X-Jet hull for the following season.
Running my boat the way it is now will make for a awesome amateur freestyle boat. Lamey PV, standard stroke 780cc w/ MSD TL. I am hopeing to compete at Nationals next year just to say I did.
