- wichita, ks
Ive been looking for a way to keep my bolt from coming lost on my steering.  Who has it and has solved the issue other than using loctite.  Ive tried it last a month or so.
			Yep same here, longer bolt and a jam nut when I ran that plate.Longer bolt and a nylock nut worked for me
Sent from my RM-860_nam_usa_100 using Tapatalk
Idk if you're open to alternative suggestions but I have done RRP steering system conversions on X-Metal handlepoles and it works flawlessy, requires only a bit of work on the lathe and some grinding, looks cleaner too.
That's awesome! Last pole we did had the four holes but still had to hog out the center. That will be such an easy setup nowSoon no work at all. I convinced them to add the 4 threaded holes so all their poles have that now. Recently we talked again about opening up the hole in the center so that change is in the works as well. So on the newest pole there won't be any modding at all.
