Putting restrictions at the inlets as apposed to the outlets will not only lower system flow but also pressure. Are you doing that for a reason db? My understanding is that this is something you would normally want to avoid.
Here is my planned cooling system:
Pump will be tapped for dual cooling. Each of the two total lines will go from pump to bulkhead lines. Then:
Line #1 goes from bulk head to exhaust manifold. Then two bypass exits from head to pissers. This is the engine cooling system.
Line #2 goes from bulkhead to the Jet Works thumb screw valve. From that to the bottom of my FPP head pipe. Then a line from the top of the head pipe to a T fitting. Leg from T fitting to a pisser. Other leg of the T fitting to a spring loaded Jet Works flow control valve. Then from the Jet Works valve to the stinger fitting.
Only reason to use a thumb screw valve is to limit the water entering into the exhaust pipe. I won't need the full water pressure/flow for the exhaust cooling system. Too much water will hurt power. I won't be limiting it way down, but I will limit it some. I will have to find the right spot to set the thumb screw valve.
But the engine will need constant cool flowing water to keep it running without problems. I don't believe in all the cold seize myths. Plus on a stock engine, it won't be a problem.
Sound ok to you? Any other time I ran dual cooling I just ran both lines to the exhaust manifold. Then I put an extra pisser off the head. The rest of the water flow was routed like stock.
PS I think Watcon has those stickers. Not a bad idea for tuning purposes. I thought of getting one of those infrared thermoters you shoot the lazer from type.
