infamy
Westside Freeride
i will be running a ported 760 with dual 44's , ada head 35cc domes, msd enhancer, b-pipe mod chamber, tbm charging flywheel. i will be riding mostly surf. what prop should i be running with this setup?
skat 12/17 freeride would be where EYE would choose to start
I got an solas concord 14/18. I run b pipe, stock carbs with vortex air filter and jetting with the pipe, milded exhaust and base port, intake port are stock. I got a wetwolf pump cone and a r&d grate with ocean pro rideplate. My weight is 130 lbs. Is this the right impeller I had?. What would you use if you was me?I think my impeller do a great job but I never tried others ... and mine is old I will need a new one so I want the best for my setup ... Next mod for the summer that may be important to consider before buying a new prop is a head for 170psi, reeds, and maybe an oversize ... thanks all!
you dont want the pitch to low! The pitch on my ski is borderline and it rev out a little faster then I would like.
