i would guess a 15/20 or 16/20
I'm with Brett on this one, I was running a 14/19 on my XS 846 SS motor in oem RN hull so the weight is within 15-20 lbs, 144 oem for 2 rides than swapped to a mag
I would say the 16/20 as the B pipe makes more bottom end , but less mid to top... Plus any time you stroke a motor it makes more torque
Your gonna have to buy a TBM which is a band aid for stock pump....
Hate to see you build the ski & not be 100% happy in the end... Biggest problem I see building these A/M ski's everyone wants the newest hull, & biggest motors, but then guys try to re write the book on setups & in the end most of the time guys aren't happy with the motor, or hull, pump , etc and there not happy with the builder.... Not trying to sound like a dick, I've had guys say this sucks or that sucks or its not right... But the setup was not followed to a T and thats what happens
Good luck with the build... Might want to talk with Brian from Thrust he had a XFS with a Dasa 930 running a 144 pump
