Tray options
RMBC Freeride
Vintage
Pueblo, CO
My tray/footholds: Basically a set of wamiltons holds with the front extended to make the tray about 1" wider (each side). Right side usually touches the exhaust tube. I have the mold for these.
TURF 2005 020 (Medium).jpgturf_2005_024 (Medium).jpgturf_2005_023 (Medium).jpg
wcjhwqkljchkljw hklqjwhnxkljwhfk2ljhf
Lol!!!!! My friggin footholds are 8" too far forward and waterlogged foam on top of a cracked hull. I just want to see different trays!
Shorten that pole a little and your holds will be better for you. I like Kscarb's widened tray. I think 227 has a pretty sweet one too if memory is correct.
chriselmore_1
high on resin
san jose ca
CIMG0186.jpgCIMG0152.jpgCIMG0164.jpgCIMG0180.jpgCIMG0153.jpgCIMG0155.jpgCIMG0171.jpgCIMG0174.jpgCIMG0194.jpgCIMG0170.jpgheres some footholds i did recently. started with some ski clinic holds. had to do alot on reinforcing to the foot holds because they were cracking all over.... hacked like half of em off so i could get em as far back in the tray as possible, and cut as much of gunwales out so i could get a wider stance. i also made some enclosures but i cut em back so only the toe of my shoe is enclosed and so i could still us em in surf stance. end result? love em. i lock in great! get in and out easy. enclosures were trimmed back perfect
SJBrit
Extraordinary Alien
Bradenton, FL
RRP has the best holds. talk about locked in!
I haven't tried RRPs, but XFTs also keep you super-locked in, are very comfortable and easy to pull out of. Howver, I'm not sure how much fun they'd be in the surf since they do put your feet way back in the tray.
Sospikey
Trying to get upside down
Sweden
I see that you have JetManiac's carabiners.
Are you using it as your Limiting rope as well?
Benny
Well, it IS my limiting rope. I made another tow rope which I keep around my waist (as per Chris's recommendations). Those carabiners are nice, very easy to operate.
