- Harveys Lake PA
ok, so i've now ran and tuned 2 sets of carbs onto my 1105. so here's how they have ended up for me at near sea level riding.
the 1st set i dialled in where ATP 48's
2mm n+s 21 psi pops
125 pilots
135 mains
low screws 1+1/2 turns out
high screws 1/2 turn out. these carbs worked well but seem quite sensitive to changes in temp and weather as it has started to warm up in the uk.
2nd set that i have now dialled in are the full spec 49's
2mm n+s 21 psi pops
122.5 pilots
135 mains
low screws 1+3/4 turns out
high screws 3/4 turn out
these carbs, while not giving any more noticable overall power do meter more smoothly at partial throttle openings and hit very well
i have been playing with ignition curves for the TS and will post up a pic when i've ran it a while without destroying my motor
i have just hit the magic 10hr mark (new hour meter fitted on install of motor) so whipped the head again for a cautionary glance, all is lovely in there.
no visible migration or immigration problems from that pesky water ;-)
I think it would be helpful if you could also list your prop and pump size / pitch that's working with this setup. I also am interested in the curve you are using
Sent from my SAMSUNG-SGH-I337 using Tapatalk
