just by knowing the mechanics, wave timing and throttle control with practice.
what else is there to say?
To much rotation??? That should be an easy problem to fix. Are you using a trim nozel? I’ve just started doing Back Flips also except I’m not getting enough rotation. I’m not using a trim nozel, I don’t think you need them in the surf. Check out this vid clip of me and tell me what you think I can do to get a faster rotation. The first 5 sec I pull one OK, but the second attempt I pancake it Big Time. I put in a slo mo of the pancake attempt to see what I did wrong. After watching it a few times it looks to me like my problem is I hesitated throwing my weight and head back until after I left the face of the wave.
Raw File: John's_Backflip.wmv
so recently ive learned to do backflips in the surf , finally, problem is now i seem to overrotate to much and land tail first or even flat any suggestions on how to have that get rotation right and ease in the nose
cheers luke
vid dosnt work john..
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/SNYjCJj4VuA&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/SNYjCJj4VuA&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
